infamy
Westside Freeride
i need to remove the impeller shaft from the pump and replace it with a different one. how is this done and is there any special tool required?
On a SJ? If so, remove the pump cone, support the pump, then press it out the back. Or, like I just did last month, beat it out with a hammer and a piece of wood to prevent damage.
I held the pump in my hands and hit the end of the shaft on the ground (spline side). If it's bad, don't worry about messing it up...
mabye i was going the worng way..that why :banghead:
lol.... it comes out the rear...
thanks, sounds easy enough. what about putting it back on? do you need a press to put it back in? any do it yourself tips for re-installing it? should i replace the bearings? if so where can i buy them? do fx-1's and superjets have the same bearing?
your right..i just took one off..very easy:banghead:
