Limiting Strap
Rather_B_SLEDDING
Is it snowing yet?
ON, CANADA!
I was wondering if anyone had any pics of how they attaced their limiting straps to there pole? As of now my ski has nothing to stop the pole from going forward and snapping the cables etc. I would like it to stop just shy of vertical for riding yet be able to unattach it for wrenching etc.. Any good ideas?
Thanks,
Matt
OCD Solutions
Rentz, GA
Here's what I did for mine. It gives you a bit more length as well.
JetPilot
'07 SJ xXx
x2
thanks for the pic boykid... now where to attach at the bottom?
OCD Solutions
Rentz, GA
I just bolted thru the hull next to the hood latch. I used a very thick, cupped fender washer on the inside to spread out any load that might get put on the bolt. I reinforced this area so it shouldn't be a problem...famous last words. I used to attach to the latch but I had it pop the latch too many times.
Rather_B_SLEDDING
Is it snowing yet?
ON, CANADA!
Is that a bungee going to the base on the pole? Is it to keep the main strap from hangin down by your feet?
Thanks for the Pics
JetPilot
'07 SJ xXx
thanks for the pics... I've been meaning to do a quick install on one, but haven't looked into it a whole lot. Good call on the cupped fender washer to distribute any pulling. :biggthumpup:
OCD Solutions
Rentz, GA
It's a proper limiting strap from Blowsions. The bungee pulls it in so it doesn't catch around things like your feet or the hood latch. The rope and bungee are all good but I've had to modify all three attachment points to be more "durable" and user friendly.
OCD Solutions
Rentz, GA
Here's some motivation for you then. :biggthumpup:
mine saved my ski a few weeks ago. i went for a stab off a cruiser wake,and got way over the bars, over inverted ,and not letting go.bent the hell out of stainless steal caribeaner.
