Highroller
X-
- Sarasota, Florida
Looks awesome. I think you will be riding very nose high. You may want to glass some inserts into the rear so you can bolt on some hull extensions if needed.
If this works out I'll get some befor & after vid to compare. At worst I'll have some opinions on what works. If the nose needs to come down I can either norrow the nose or widen the tail.
I did'nt consider how harsh flat landings might be but I should'nt be in the air anyway. My knee are shot, bone on bone, with no cartilage left. Hard compression swells my arthritis & binds my leg:frown:
I did consider that this shape will want to ride higher in the water and will swap ends easily. It could be what I'm looking for, or not. :cat05:
you definately are a true shredder, you'll work it out... :Banane01:
:haha: I do tree work. I'm shreding all day, every day:biggthumpup: I'm in the middle of replacing a cracked drum in my shredder today. Here's a pic of the part that zapped hopes of time off for a long time:frown:
that is damn funny... :cool2:
professional shredder:Banane01:
For those of you that haven't seen Joe ride.
