new first mods in the tech faq
onesojourner
I use a thumb throttle.
springfield, mo
I think it should be noted that this is more for a surf oriented ski. for flat water reinforcing should be near the bottom for most of us. unless we are hitting massive boat wakes its going to take a very skilled rider or a lot of power to get to the point that you are going high enough to brake a hull.
just my 2 cents.
option 1
in order of modification:
1. reinforce skis engine compartment and tray
2. worx 201 intake grate
3. skat trak 12/15 freeride swirl prop
4. cut your pole down to -4"
5. 0 degree straight bars/X-metal steering
6. footholds
7. Hydro Turf
8. Blowsion Tubby 2's (sponsons)
9. one way valve/scupper
10. dual cooling
11. Factory B Pipe
12. milled stock head
13. MSD ignition
14. porting (LPW)
15. lowered hood kit (tons of options) I am using the waterdawg hood, very well priced
16. more motor and hull upgrades
It's my belief that handling mods should always be done first before engine mods
option 2
Stage 1
-Worx 201 Intake Grate/JD Intake Grate
-Skat Swirl
-Stick with stock rideplate for now(D-cut later)
-0 Deg Bars
-Bilge Pump
Stage 2
-Footholds/Turf
-Shorten Stock Handlepole
-Shortened Turn Plate and UMI Steering if you dont mind spending a little more
-Seal Stock Hood!!!
-Reinforce
-Hood Straps/Handlepole Limiting Strap
Stage 3
-Bpipe
-Girdled Head
-Carbon Tech Low Tension Reeds (Until you're ready to spend the big bucks on some really good reeds)
Stage 4
-Enhancer/Modified Stock CDI
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Aftermarket Handlepole
-Scupper
-Tubbies
RECENT THREAD LINKS:
Unmolested 02 SJ.....For now.....
advice on mods for stock superjet
Help and advice needed for my 701 freeride/freestyle build
http://www.jetskier79.com/gallery/v/yamaslut/album40/
help what mods to do to this superjet.
Superjet build up, some advice needed.
TECH SECTION LINKS:
browse through this section for tutorials on listed mods
http://www.x-h2o.com/forumdisplay.php?f=26
feel free to add your ideas and mods you would do in order of mod... we can make it the end all for people wanting info on first mods for a SJ...
make a list like FLy and I did...
beachedflunkey
wavejunkies
Virginia Beach
I'd recommend a quick-steer mod, cover front air intakes / increase rear intakes (rn only?), and hood straps/limiting rope as stage one under option 2.
And add one-way valve as an option when doing footholds.
Mark44
Katie's Boss
100% one place
o
Not at all, reinforcing for flat is a must. My ski would have been in pieces right now if I didn’t reinforce. You need to ride the Mississippi with us some time.
just my 2 cents.
option 1
6. footholds
7. Hydro Turf
10. dual cooling
11. Factory B Pipe
13. MSD ignition
14. porting (LPW)
option 2
Stage 1
-Skat Swirl
-0 Deg Bars
-Bilge Pump
Stage 2
-Footholds/Turf
-Seal Stock Hood!!!
-Reinforce
Stage 3
-Bpipe
-Girdled Head
Stage 4
-Lightened Flywheel
Stage 5
-Porting
-Bigger Carbs
-Better Reeds
Stage 6
-Aftermarket Hood
-Scupper
-Tubbies
TECH SECTION LINKS:
onesojourner
springfield, mo
but more than likely some one who is just starting to build a boat, most likely their first boat they wont be able to do what some one like you who has been riding for a long time can do. Also you should treat it more like a surf boat if you are hitting massive cruiser wakes.
norcal ex
X-H2
San Jose, CA
I would say flip around stage 5 and 6. having a shorter pole and lowered top deck is much more important then having a ported engine with large carbs. I coul ddo 90% of my tricks with a stock 701 engine and dual 38 carbs and a lowered top deck/shorter pole. However, if i had the porting and larger carbs with the stock hood and pole i would only be able to do about 50% OR LESS of the tricks i currently do.
Waste Land
Non Multa Sed Multum
Florence, AL
If your going the length to have the engine ported....buy a damn REAL aftermarket head. Billet aluminum witha girdle kit is no NEEDED but very highly recomended. Engine vibtraion and more compression. It's easy to crack a cylinder.
In my honest opinion.....
Stop worrying about tons of crap to put ony our ski....learnt or ide your ski better and get some good things down before slamming $$ into it just yet. Sticka pipe, head, prop and grate on that thing and just enjoy it. 90% of people that buy SJs now seemt o be more worried about parts lists then riding. I mean reinforcing is good for any ski and i completely agree...but leanr some trick first and then build as you go....
Michael Ratti rolled a stock RN with a pipe, head and prop on flat water for a long time....it cna be done on even less if you try hard.....i cant and wont be able too but just something to think about
I have stress cracks from flat water BR attempts....:bigeyes:
