slickchaos
Chaos on a SJ
- Mass/NH
guys i took quick look in the back of the SJ and didnt see a nozzle to flush the ski for fresh water. does it not have one or am i looking in the wrong area......
98 SJ....
98 SJ....
see the red hose. this is where a flush kit goes on an sj. This picture is of my fx1 but the flush is in the same spot on your ski.
if he had the stock exhaust...1998 Superjet
- B Pipe
- Worx Intake
- Worx Rideplate
- UMI Handlepole Spring
- Solas SS impeller
You can always run it at full throttle in the driveway while running the hose straight into one of the carbs to flush it.
That works better with salt water, though.
You can acutally clean carbon from your motor with water by pouring a little amount at a time down the carb...
I've only seen it done on cars, but I guess you could do it on a 2 stroke?
yes its has a stock head... here engine pic..
I spy what looks like a flush connection.What's that yellow hose with a T-Fitting at the rear of your carbs for? :biggrin:
