cookerq62
Life's Been Good
- Upper Bucks, PA
What jets/pop off should I be running in dual 46's?
motor:
-83mm Ported 61x ports raised a bit and the sleeve on the intake side is notched
-ported 62t cases
-b-pipe limited
-rad valves
-stock timing (might do a slight static advance)
-low compression like 155lbs on a decent gauge
-prok's with prefilters
-gutted/modded squarenose hood
Right now the carbs have:
150 high
102.5 low
1.5n&s and a black spring
I'd like to keep the needle and seats if at all possible as they aren't cheap and I have a few 1.5 spares. With a single 44 I ran 122.5L 140 high 1.5N&s with a 115g. The motor ran way rich up top. I want something I can set and forget as far as jetting goes.
Thanx,
Ryan
edit:
110 main
117.5 piolt
2.0 ns
95g pop off
Thats what I am finding for dual 44's are 46's that much different?
motor:
-ported 62t cases
-b-pipe limited
-rad valves
150 high
102.5 low
Thanx,
Ryan
edit:
110 main
117.5 piolt
2.0 ns
95g pop off
