I don't know....stock rideplate is pretty light already.
Yes stock plates are very light, probably very close to the weight of a composite plate...... save you $$$...... but yes my protec plate is almost 3lbs heavier then a stocker.....
I saved 4lbs dry with the cart tank
about 4lbs dry with XMW Waterbox
and about 3lbs by using the XMW front exhaust only..... pulling the stock rear exhaust out..... I put my scupper there.
My WD hood is about 13lbs..... not sure on stocker weight.
5lb battery
Kevlar reinforced tray with no foam?????.......hmmmmmmm......
stock handle pole...... lightest on the market.
.......... hmmmmm maybe a total loss and Trinity Hood will come next!
Im not stoppin untill I hit 250lb:haha: :sneaky: :woot:
270lb with a sponged up stock pole pad, and full kevlar reinforcement! :haha: :haha: :haha: :biggrin:
