Conquistador
B-Saw
- Virginia Beach, VA
I've broken two flywheel pullers today on my 94 550. Are these things threaded on? I'm really at a loss right now.:frown:
Whats breaking on your puller? If the threads are getting messed up then used some good quality oil.. like 90weight or something. Get the puller tight and hit the part you put the wrench on to tighten it.. hit it directly toward the flywheel not at an angle. The lamp you are talking about might not do it becuase it will heat the whole area and you need to expand the hole in the flywheel. I know lowes or home depot sells a little propane torch deal used for plumbing, but I dont know if it will getit hot enough to do any good. You really need the whack from the hammer to get it off though.
Jay
Well I hope they can get it off for you.. when you put it back on dont tighten it as tight as it was.. It wont come off if it is tight, but It will get stuck on there if the nut is overtightend. Now you have us waiting on pins and needles for what you are being secretive about.
Jay
