sjetrider
- in the 615 (Nashville)
My sons boat is a ported 701 w/
ADA head 33cc domes 205 comp. (just changed from 35cc since last ride)
MSD enhancer (just installed from my boat since last run)
Riva Alum flywheel (just installed from my boat since last ride looked fine)
B-pipe mod chamber dual water (just added dual water since last ride)
twin 44 Mikunis 110 pilot / 120 main 1.8 n/s (21psi pop off) (carbs are like new but have been run before like 4 years ago, I just bought them and added new n/s and jets) They look new inside and out.
Riva mnfld w/ no spacer, pro series boyeson 2 stage reeds (same set up as before except I removed spacer)
My problem :
Runs great and crisp on trlr and for about 2-3 mins. in water. Then it turns to CRAP running like it is on one cylender. Let it sit 2-3 mins. and it runs fine for 30 feet then accurs again.
I thought it could be reeds as I saw some smoke coming out of rear cylender, I removed mnfld and rear read was hung open like 1.5mm but in good shape, I flipped read over and seemed fine so I reinstalled. I was also sceptical of the enhancer so I changed it back to the OEM modified CDI. I OHMS checked stator wires, plug wires and coil wires (all seemed fine).
I took it back out and it did the same exact thing as above.
Last night:
I removed the head to inspect and replaced compression O-rings (cylenders & pistons look fine), rechecked compresion and was @ 205 rear 208 front. Put the Enhancer back in and double checked all w/ ohms meter again, decided to change the coil even though it Ohm's tested fine (figured it might be getting hot and breaking down). I emptyed the gas tank to check for water (near none), chanded the check valve (even though it seemed fine), changed the fuel filters (just in case) and double checked pop off on carbs (checked fine). The spark is excelent and plugs are brown and seem dry.
Boat once again runs fine on stand.
Anything else I should try before I test ride tonight? I am supposed to leave for Orange Beach Friday after work and need this boat running and I only have time for one more test ride before I leave. What else can I check, has anyone had this issue in past???????????????????
Any and all help appritiated.
Sincerely,
Desperate in 615:dunno: :17: :17: :17: :17: :17:
My problem :
Last night:
Sincerely,
