raider/superjet parts swap???
W
wydopen
hi my buddy has finally decided to ride a superjet and we have the oppertunity to pick up a round hull...he has a wave raider 760 that i have also convinced him to tear down...what is compatible between the two??..pump? ebox? etc...im sure someone has done this before on here..btw i searched and couldnt find what i was looking for..thanks
WaveDemon
Not Dead - Notable Member
Hell, Florida
trim nozzle, I think the whole pump other than the drive shaft. some of the cables may work too. start/stop swith, throttle... I've got 2 raiders in my yard I"m parting out and keeping some of for my sj projects too.
don't forget the cas cap. my raiders are a sweet fadded purple. can't wait to throw that on the SJ!
W
wydopen
sweet..so ebox, pump and motor...sounds like we got a round build coming up
michael950
for me to POOP on!
Houston, TX
Forgot about the pump, disregarded it because the shafts are not the same... I think the intermediate bearing and shaft might be usable.
sjetrider
so the pump fits the shaft is just different or???
The wear ring will not work unless you run 8 10mm bolts & nuts to hold the venturi, vien housing and wear ring together instead of 4 long 10mm bolts or put heli coils in pumpshoe end holes of wear ring.
The intermediate housing works but not the drive or intermediate shafts, the couplers work.
Hood latch works
elec. box works
s/s switch works
Of course the motor & bed plates, but not the motor mounts.
The Throttle cable works also, but not the steering cable.
I think thats about it. The tanks and waterbox mounts & straps dont work.
:biggthumpup:
W
wydopen
Hood latch works
elec. box works
s/s switch works
:biggthumpup:
thanks
W
wydopen
does anyone have a pic of this mod in the buildup section...is it even worth it or would it be better to just find a sj pump??
No pics neded you simply take out the long bolts that hold the pump pieces together and replace them with short bolts ie you are bolting the pump shoe to the wear ring and the wear ring to the vein housing,thats really all there is to it.
WAB
salty nuts
coastal GA
I don't know what the 760 raider's motor mounts look like, but I swapped over motor, wiring, & motor mounts from a 1994 701 raider into my SJ. (Pump was trash)
I know the 1100 raider's mounts are different, maybe the 760's are too.
