Reed spacers
RiverRat
Louisville, Ky
They help prolong reed petal life and possibly allow for more unobstructed flow to the transfer ports, but don't expect to feel a performance difference.
#ZERO
Beach Bum
Florida - U.S.A.
I think most people use reed spacer plates for installing longer reed cages and air filter clearance issues.
With the spacer plate installed you lose some signal on the low end, not to mention more gaskets and possible air leaks.
On most set-ups, your not going see any improvements unless it's set-up wrong in the first place. Some design their engine to use these, and in these cases, I'm sure they are benificial. For your stock set-up, they are snake oil. You can buy extended adapters from Riva for aftermarket flame arrestors so they fit. I have yet to have these improve reed life on any set-up I've had. the theory is great, but real world has yet to show me the results.
Supertune swears by them, the guy seems pretty sharp, pm him if he doesn't chime in.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Here he comes
Here comes Reed Spacer
He's a demon on wheels
He's a demon and he's gonna be chasin' after someone
He's gainin' on you
So you better look alive
He's busy revvin' up the powerful Mach 5
And when the odds are against him
And there's dangerous work to do
You bet your life Reed Spacer will see it through
Go Reed Spacer
Go Reed Spacer
Go Reed Spacer, GO!
He's off and flyin'
As he guns the car around the track
He's jammin' down the pedal
Like he's never comin' back
Adventure's waitin' just ahead
Go Reed Spacer
Go Reed Spacer
Go Reed Spacer, GO!
waterfreak
I had a vision!
s florida
Here he comes
He's gainin' on you
Go Reed Spacer
Go Reed Spacer
Go Reed Spacer, GO!
He's off and flyin'
Go Reed Spacer
Go Reed Spacer
Go Reed Spacer, GO!
Wow! Is this what happens on the X when there is no drama!! :biggrin:
