Yeah this is a tip that really helped me and I noticed an immediate difference. Look over the oppsite shoulder when you roll. If rolling to the right look over your left. What it does is makes the ski twist into a nice clean spiral roll.
When rolling to the right: looking over your left shoulder forces the right shoulder down and the left shoulder up and around. It also gets your eyes around faster so you can spot the landing. It is very awkward at first but it works!!!! It is all about form. The end result should be a roll where the nose is pointing forward. You should land on the same line that you took off on, or close to it. I find that when you roll to the right and force your head down to the right the tail of the ski just flies and makes a large loop (observation) making you land off to the right b/c you are leaving that initail line. However when you use the other method and twist the boat the ski rotates on a axis. I am no expert and my rolls need allot of work....I have only done a handful that I have been satisfied with, but I just started trying hard this season. Plus the only rolls I have done is completly on flat water..no wake, not set up wave. I would run in a straight line pull the trim on a pre-hop on direction, pull it again to bring the nose up, crank the bars, look over the opposite shoulder and just hold on b/c I would rotate fast. I went back and forth not looking over the oppsoite shoulder and the results were night and day to me. Try it and feel it. It just feels more controlled to me.
Now go watch some Eric Malone flatwater video's :cheer: Better yet go to EME freestyle clinic. It is not overrated. Just attend with a specific trick you want to work on and a open mind.
Hope that helps......*thread hijack over* :biggrin:
