Tigercraft V3 Build
Okay friends. The ski has arrived, it arrived here at 2pm at work and I'm mentally already checked out. Hard not to be anything other than excited at this point because this was a once very young adult dream that is now within reach for my older, fatter self. That out of the way it took me 2 years to save for this hull and a Christmas bonus on top of it.
This will be my very first AM build. Just know I'm not made of money but I'm definitely in the mindset of buy once, cry once. If that means it takes another 2 years to build so be it.
The reasons I went with tigercraft is because of all of the amazing reviews iv seen and the durability of the V3 ski itself. The reason I went with the V3 is because it had seem to work well with most applications I wanted which was boat chasing and surf.
After much though and poking around my plan right now is to put a jm 781 in it, Powerfactor lay down pipe in it and a Solas 148 mag pump with a pro xscrean trim system. There is obviously a bunch of other parts that I need but these are the next big financial hurtal that I'll be facing. Iv got a few stock 701 engines that I'm trying to sell and a few odds and ends on kawi 550s and wave raider parts to help advance the purchase of the engine.
I will update everything as they come and take the time to document everything I can. For now I will enjoy my very VERY expensive garage ornament.
All help and suggestions as I will need it surely is greatly appreciated. Here she is!
Man beautiful ski there! I did the same thing a few years back and sold my worn out Super Jet and saved for a few years and bought my first aftermarket hull brand new. What saved me the most money in the build is I was able to purchase another nice round nose that had all the good parts and nice motor already done. Then I stripped it and used everything on the new hull sold the round nose hull and got back half what I paid for it whole.
thank u sir. iv heard alot of guys doing this. unfortunately everybody wants a premium for there rn superjets nowadays. im always keeping my eyes peeled for the right deal to float around though.
Keep an eye out for cheap sit downs too, they have many of the same parts without the SJ markup
Ya iv already pillaged a 96 wave raider, and about to tear into my 94 to get the goodies out too. Unfortunately I can't use most of the parts. I can press out raider mid shaft and replace with sj midshaft but still need sj shaft. I don't know what skis come with stock dual 44 carbs, that would be nice to have.
Definitely not worth buying a running superjet just to strip it down. Find a non running sit down and use that. New oem tank can be found on partzilla.com. go ahead and plan on rebuilding the engine before putting it in the new hull for piece of mind.
Any 64x 760 will have dual 44s. I'd personally recommend going with the a/m mikunis over the oem 44s like on the 760. The a/m 44s already have the chokes removed, include primer fittings abd also have additional fuel and air bleed holes which supply additional fuel off idle that helps tuning in that circuit. If you're on a strict budget the 760 carbs will work OK. Hit up @Sasquachcrap for a driveshaft he can custom make any length shaft you need with quick turnaround.
When I built my first superjet I started with a hull with hood and pole. I found a 93 square nose and 96 raider for 600. Between those two skis I had enough to build the superjet. All said and done I was into that superjet for under 3500 including 1500 for the hull and basic engine refresh.
The one thing I have not looked into.is a/m carb manufacturers. Good brands to look at?
Just get mikuni 46s and call it a day. Those will work well on every engine combo from a ported 701 to a dasa 950 and everything in between. The a/m are just actual mikuni sbns you buy online or from someone like jet maniac. They'll have t handle adjustment screws, 90 degree fuel fittings, extended throttle shafts for easy dual carb modification. They also have additional fuel bleeds for the idle circuit which makes the popoff/ lowspeed circuit easier to tune. You'll spend about 500 on the carbs for new but they're well worth not dealing with carb hassles.
Update. I just put my deposit in for a JSN 964. I'm getting a pair of 46's new and some v force 3 reeds. One of the last big hoops iv gotta jump before everything else just becomes "bout another thousand". Many things have changed since the original plan. Also alot has changed for me in my living situation as i hardly pay rent anymore as im living with "family". Getting married in November, so that had to be saved for too.
Spoken with alot of people in this industry. So far Jordan has been nothing but awesome. Same could be said for Paul. Tony is a G and picks up his phone when he has free time to answer some of my dumb questions.
Iv got 2 701 engines left that I'm trying to sell complete still and just start with all new crap. One 61x that im sure has missing compression in the front and a 62t that looks like it has salt water in the raider it was in. Aside from the midshaft I'm going for broke. As of now, once I pay Jordan in full I'll be in whole about 14ish thousand. (After doing a rough estimate i imagine this is going to cost me somwhere around 20k+) I have a stock 155 pump and a couple raider shafts I plan on sending out to get sized for the hull and pump setup. The stock pump is probably only gonna be there until iv got extra nickels rolling around. After that I'll upgrade. To what will have to be determined. I'd like to stick with a 2 piece pump but unclear as to what specific pump to get.
The next big hurt I plan to tackle is electronics, pipe and manifold. I was told by many people that the TNT pipe was the go to. Iv also heard getting ahold of a manifold might be tough, although iv done 0 research myself. I have stock 62t electronics but don't know what condition they are in. I figured since I'm doing powercenter completely new I'd do new electronics too. I know effectively nothing on ZEEL electronics but it looks like people are using that. How much of the stock electronics do you need to run it? Or is the zeel a complete replacement?
Anyway that's the 411 right now. Motor setup should be here in about 2-3 months. Ill post pictures when i get it. Im pretty excited and its Great wedding gift to myself if you ask me.
964 will be a good time in the v3. One of my buddies put a 1021 in his with a similar setup as you. Hes also running 46s, a zeel cdi with 760 electronics and a oem 155 pump.
I can tell you from his experience some things he's found getting his tuned.
First thing- especially with the 964, you'll want to cut some air holes in your hood to let the engine breathe. The pole breathers are not anywhere near enough air for that engine. This was verified with a m1 that also has a 964 but no good breather. The v3 and m1 use the same hood and when the m1 tried rhe v3 good with the breathers, it wouldn't even get on plane it was sooo lean.
Hes running a b pipe with a mod chamber,not a tnt. The tnt may be hard to come by if you don't already have it. I know many people run the power factor pipe wet with great success and that would be my go to if I couldn't find a tnt pipe. That said, he bought a new impeller for his 1021 I think a 9/15? I do know it measured different than advertised and he ended up going back to the 6/12 he was running with his 701 and it ran better wity that impeller. When you get to measuring the drive shaft make sure to get a good measurement. I know he had some modifications to do there but im not exactly sure what he had to do.. I think he had it made slightly longer. Ill ask him when I talk to him again and let you know..
There are 2 zeel cdis available. Ome for the 61x/62t electronics and the 760 electronics. The both use all oem components with the zeel cdi. Like the msd enhancer. Only the zeel is completely programmable with a computer or programmer. With the 760 ignition, you can remove the charging magnets from the flywheel for a total loss because the 760 uses a hall effect pickup and the 62t is a magneto. Both work extremely well.
would love to see how he made the modifications to the hood. it already make my b-whole tight thinking about doing that as this project is worth more than may truck already. im thinking im going to run pfp. tons of tuning already done on the pipe by other people running similar setups and it come with a waterbox.
what i imagine im gonna do is have the pump setup installed with engine setup installed, measure from point to point and then send out flywheel to get lightened and shaft to get adjusted. id also be curious if he forgot to account for something when measuring or ran into something he did not expect.
UPDATE on engine. cylinders are apparently getting finished and shipped back soon. that means pop pop is getting an engine soon.
X2 on the pole breathers. Pole breathers alone poorly feed a 61x stock pipe single carb.
If your buddy was running an OEM 155 he probably wound up lengthening the shaft 10mm to compensate for the 10mm further back the 07 shaft in the 155 sits. I wound up pressing my mid shaft in all the way and running a few extra spacers between the shaft and coupler so I could use off the shelf drive shafts.
How's the build coming along?
Haha after watching the world finals in havasu it's not going well. Makes me wish i was jeff bezos kid. But the engine should be finished soon. Jordan had alluded that the Cylinders are coming back from the place where they get nicklesealed so once that is here ill post pictures. Next to the "still in the crate" ski and think about how cool it would be if they could be working right now.
Are we gonna race to build our V3s? :cool:
i owe mom 6k for my ktm 300 xcw and just paid 3k for food for my wedding. i still owe jordan for the remainder of engine when it gets sent, thankfully i paid for the carbs and intake already. your gonna be much further ahead of me. but i think the answer is if i just dont eat for the next 6 months ill be on the water this summer, could use the weight loss anyway.
on a serious note if my mom excused my debt as she likely doesnt need the money as shes doing VERY well for herself as a lawyer, im hoping i can move along with the purchase of the pipe/electronics. after that trim. then all the small stuff. shaft, couplers, mat, controls, cables ect. that end of year bonus better be spectacular.
