Nah, the ignition coil isn’t the issue — I’m talking about the charging coil inside the front cover. A lot of people don’t actually understand how this works, so it’s worth explaining properly. Whenever you move a magnetic field through an iron core, it increases the magnetic flux and that induces voltage in the coil wrapped around it. The iron core doesn’t “amplify current” — it just improves the magnetic coupling, which bumps the voltage up.
If you’re running aftermarket flywheel magnets that are too strong or not matched to the stator winding, you’ll end up pushing way more voltage through the system than it was designed for. That’s when stuff starts cooking — the stator windings get hot, insulation fails, and before long the CDI cops it too. Even though the trigger pickup is fixed, a stronger magnetic field and EMI can mess with the trigger signal, which can throw your timing off or make it unstable.
This is exactly why I prefer the 760 setup. It’s got a fixed trigger reference, runs off a clean 12 V DC supply, and it’s just a more stable and reliable system than the old 62T. Honestly, I’m always shocked when people say the 62T is “better,” and even more shocked when it’s coming from people who should know better.
Bottom line: if you’re blowing CDIs and stator windings while running a hot aftermarket flywheel, that’s probably your problem. The magnets are too strong, the voltage goes through the roof, and the rest of the system pays the price.
