2016 Rickter Edge cooling tubes
Bay Area
Ok I got most of the gremlins out of the build but cooling tubes through hull are leaking one is really bad.. does someone sell the tubes in the correct size or what I need to buy? My hull is a carbon hybrid hull so I’ve heard certain metals do not bond well? My guess is aluminum is the issue and i probably need stainless tubes ? Any help would be great! Thanks! I’m sure my foam is soaked but that’s a problem for the winter
Had the same problem with my Rickter, I ordered from McMaster, convenient and quick, not cheap. You can do better on price if you shop it. Here’s how I did it. Remember to get a larger tube for your trim, I don’t run trim so I used 3 equal sized tubes and just run a stock siphon with the 3rd tube.
Bay Area
Thank you! I will read through it!
