Zeel 62t
They perform better,
But they don't last long, lots of people had had good luck, but I also know a lot of people they have failed on.
An msd will outlast your ski, a zeel you might be replacing every year.
LOTO
I have a couple seasons on one in a SJ and a season and a half on another one in a 1200 Rickter. Both have been perfect. I also always run a separate ground cable from the ebox to the battery. Paul at LPW sells them and can set them up for your application if needed.
Jr.
Standing Tall
Staff member
Hot-Lanta
Zeel is constantly improving the Y62t cdi. Failure rate has really improved over the past several versions.
The problem now is voltage spiking from the use of Lithium batteries. As long as the Lithium is not spiking over 14.5v
Little to no issues. Performance over the Enhancer is not really even a far fight. The Y62t wins all around
The ability of custom tuning and curves makes all the difference in performance applications.
P
Ive got 5 seasons on my 760 zeel. I went through 2 of them before figuring out how to properly seal the ebox. Keeping water out of the ebox is essential to any electrical component lasting.. Zeeltronic has updated the 760 model since mine to a new,style cable instead of the 10 pin connector which was a seeping point on the older model cdi. Never messed with an enhancer its not really a fair comparison..
What was the key to sealing the ebox? I have a 62T zeel I'm looking to maximise its life.
I have a handful of the old o2t style that I have been using in various different skis for something like five years or so. I've had one failure and it was in an ebox that had water in it sitting outside for a Minnesota winter so I'm saying that one is on me.
I like the idea of the 64x style trigger better, but I have no personal experience with a 62t zeel. Mine are all 64x or kawi.
waxhead
wannabe backflipper
gold coast
I spray my wires where they go through the eletrical box wiht crc softseal and it and it does the same thing. thats the only issue i have with zeeltronics as well is the water in the eletrical box
