Unfortunately for now I'm stuck with this 61x and was looking to go more aggressive than the previous templates that I have run.
I've been following the other thread on "How to Turn Your 701 62T Into a Real Mini Weapon". Would you be open to a parallel thread on "How to get second place with your 61x"? Second place is also fine since I'm not racing and just throttle blipping around.
Outside of the actual 62t I have everything else on hand:
- ADA head with domes that should put me at 195 psi (squish will be too high at 1.27mm based on notes)
- 4 hole sbn 44s because i got them on a package deal, vforce reeds
- zeel with the wax v3 curve on it
- mod b-pipe
Thoughts:
- ideally deck the cylinder .4mm to fix squish - thicker base gasket?
Porting:
- Widen exhaust to 65-70% - raise height xx mm
- Raise transfers xx mm
- Raise sleeve height 8mm?
- Widen/taper boost port tunnel
I’m running a 12/18 with a solas 12 vane pump. I did have a 11/17 in it and it was a rocket but was giving away a lot of top end. I had run this same engine with a 10/16 hooker and it rips off the bottom and throttle response.Wax I apologize if I've asked this before but I don't' recall, what sort of impeller/pump setup are you running with these 195 degree exhaust port cylinders.
Seems like it's going to want a pretty low pump load to really shine, everybody with their 10/16 hooker that they run on a 179 degree stock 61x cylinder with a B pipe and 35cc ADA head might need to make some adjustments.
Thanks Jimmy. Im a small bore guy for sure, can explain it soon but im about to head off to the gym. Please remind me in a few days and i will put something togetherA wicked idea, and another clean print! Hats off to you Wax. Thank you for sharing these, and for giving the community access to FX1 chambers
Im curious if your willing to pass along any other pieces of the recipe. Particularly on a 61X cyl. I've read some guys like to stick close to 81mm becuase the transfers struggle to flow the bigger the bore, but it seems your increased blow down should help address this, do you typically go to 84mm on a 61X? Also curious what compression and static timing you run
Its in a 2008 plus hull. I was using a tbm ride plate an an r&d grate, it was with one of our pump cones and a protec mach two pipe. I have since gone to a prowatercraft plate, our sxr chamber. I went back to 46mm carbs from 48s to take some hit off it as it was beating me up, I also went for a solas stator as they hook up better than a cone but they are twice the price and heavy. Its a well rounded race boat nowPulling that impeller in a mag pump would be awesome. What hull were you racing that in? Assuming that was with the rest of your mini weapon setup 84mm, .8 squish, 200 compression, dual 46s, zeel, your sxr chamber, and a few other secrets?
