This is our Watcon Rear exit Exhaust conversion for Yamaha B1 Blaster, and Raider 700. Comes with Stainless pipe and flange, Block off for original exhaust outlet hole, and hardware. Sounds better, and lets the exhaust out the back so it does not dry rot your cooling hoses, and make a...
I had a fabricator buddy make me a few.
Pretty simple part for anyone confident with a tig welder
just needs a small kick one direction, the back of the ski isn't flat relative to the centerline of the hull
i’ve seen the watcon kit just not in love with the look of it. would ideally like something that has the fasteners recessed into the flange and to look a little more appealing
Exactly! I used one on the WB1 I had. Went right on the stock long hose. It was a superstock so I wasn't running a waterbox, only a silencer. You'll just have to figure out the exhaust hose end in the engine compartment.
