Prop pitch and detonation
waxhead
wannabe backflipper
gold coast
Here is an article we just uploaded on our website,
Built for Speed, Tuned Like a Tractor: The Ugly Truth About Over-Propping​
by jared martin June 26, 2025
The Truth About Over-Propping Your Ski — Why It Hurts Power, Builds Heat, and Fools You Into Thinking It's Fine
Tuning jet skis is all about balance — airflow, fuel, timing, and load all working together to keep the engine in its powerband and the pipe doing its job. But one of the most common mistakes people make, especially after adding performance parts, is over-propping.
It usually starts with good intentions: you’ve added more power, so naturally, you want to put in a steeper prop to convert that into more speed. But when that prop ends up being too much for the engine to handle, things go backwards — and many riders don’t even realize it until something goes wrong.
So, what does over-propping actually do?​
When you put too much pitch in the impeller or choke the nozzle diameter, you’re asking the engine to pull a load it simply can’t manage at the RPM it was designed to run. It's like trying to take off in a car using 5th gear — the engine bogs, doesn’t rev properly, and works harder than it should just to stay alive.
In a jet ski, the signs can be subtle at first:
  • Throttle response feels lazy.
  • The ski takes a little longer to get on plane.
  • You might still see a decent top speed — eventually — but it’s not crisp.
  • The engine doesn’t sound sharp; it drones and strains.
But that’s just the beginning.
Heat builds fast — and you won’t always see it​
As the engine struggles to spin the impeller, it's dumping more fuel and air into the cylinder, but because it's not reaching the correct RPM range, the exhaust gases are moving slower than they should. The tuned pipe stops working efficiently. Instead of boosting performance, it starts holding heat.
That heat radiates through the pipe, into the cylinder, into the combustion chamber — and before long, you’re dealing with heat soak. You’ll feel it too: the ski might feel strong on your first pull, but by lap two, it’s down on power. You start wondering if something's wrong with the ignition, or maybe the fuel — but the real issue is that your engine is suffocating under load.
Can’t I just cool the exhaust more?​
Yes, you can — but here’s the catch: you're not fixing the problem, you're just hiding it.
Some systems use heavy water-jacketing or extra water injection to keep the exhaust pipe cool. On the surface, that seems like a good thing. The pipe stays touchable, the hoses aren’t melting, and it looks like everything is under control.
But in reality, you’ve just cooled the exhaust gases too much. Tuned pipes need heat and velocity to create the pressure wave that helps fill the cylinder. If the exhaust is too cold — or never reaches resonance because RPM is too low — the pipe won’t “come on.” That means less scavenging, less torque, and less horsepower.
You're staying cool because you're not making power.
Detonation doesn’t care how it looks​
Here’s where things get risky. Most riders still run stock ignition, which holds timing in the high teens or low 20s all the way up top. That works — until you introduce high engine load and heat buildup from an over-propped setup. Now you’ve got a recipe for detonation.
You may not hear it, but it’s there: subtle, damaging knock that slowly eats away at pistons, rings, and domes. And all the while, you might be thinking, “It’s running clean — it just feels a bit lazy.”
What it really feels like on the water​
This is where it becomes obvious to a rider who’s paying attention:
  • The ski pulls strong at first, but fades after 2–3 minutes of hard riding.
  • Mid-range feels soft, even though you're wide open.
  • RPM is lower than it should be, despite no obvious tuning issues.
  • The pipe or cylinder head feels unusually hot by hand, even with water flowing.
  • It sounds flat — no bark, no snap — just a dull, overloaded drone.
The fix is usually simple​
  • Drop the impeller pitch a degree or two.
  • Open the nozzle slightly to reduce backpressure.
  • Make sure you're hitting your intended RPM — and not just chasing top speed.
  • If you're tuning by feel alone, pay close attention to how the ski revs — not just the number on the dash.
The bottom line​
Over-propping is one of those tuning mistakes that feels like you’re heading in the right direction — until you’re not. It can make a strong ski feel lazy, cause heat soak that sneaks up on you mid-session, and ultimately cost you the performance you worked hard to build.
If your ski fades after a few minutes, feels boggy despite clean tuning, or needs heavy exhaust cooling just to stay alive — take a step back and ask: am I overloading the engine?
Let it rev. Let the pipe do its job. You’ll make more power, run more reliably, and actually enjoy the performance you paid for.
Great write up. Thanks for posting. I think most guys on the water aren't into the fine tuning aspect. For them, if it runs ok and sounds good then that's good enough.
dfw
It’s mostly important for skis with good pipes on them. Stock SJ exhausts and single pipe triples will only gain or lose low speed acceleration. The carb tuning will change but still be easy to adjust. If it has a pipe, the pump load needs to be light enough so there is little lag in power response. If it’s lazy going from idle to full power it will also be more difficult to tune the carbs main circuit.
The bottom line​
Excellent write up! Do continue! I’m going to use my current build as an example. I intentionally started with what’s probably too low of a pitch for the reasons you pointed out. So, in the chase for the Holy Grail of Ultimate power increasing pitch would be the next step. If you’re on the pipe, hitting max revs, plugs are perfect, piston wash is perfect, is the next step increasing pitch till it bogs and rejetting for the higher pitch, OR, backing off the pitch because the read on the motor ( plugs, wash, acceleration) WAS perfect and that’s only what the motor can handle?
waxhead
wannabe backflipper
gold coast
That’s the real question, isn’t it — when is it just right, and when is it too much? I usually start like you: tune the engine first and let it show where it wants to sit in the RPM range. Let me use a ski I just built for myself as an example — it’s a ported 760 with all the good gear on it. Not a full race ski, but a fast rec/race setup.
I originally had an 11/17 prop in it. It was doing about 85 km/h — that’s roughly 53 mph — and pulling 7340 to 7380 RPM. The speed was a bit low, but the RPM was exactly where I wanted it. Then I swapped in a 12/18, and straight away the RPM dropped to 7200. That might sound like a big drop, but I also gained 6 km/h, bringing it up to 91 km/h (around 56.5 mph).
Why the RPM drop? If you look at any power curve, it climbs, peaks, and then drops off. With the shorter prop, the engine didn’t have enough load on it, so it revved past the power peak. When I installed the taller prop, it loaded the motor more and brought the RPM back to where peak power actually lives — it just didn’t have enough torque to pull past that point.
Next step for me is to try one size taller again and see what happens. Then I watch the tacho closely on long runs. Honestly, I’ve found it’s cheaper in the long run to buy props than pistons.
Obviously, this example is a bit more aggressive than your average rec ski, but it’s not full race-spec either. On milder setups, you can often hear when something's off — they sound hollow or lazy. A good tell is a “counting back” tachometer. You want a fast-responding tacho that shows small, gradual drops — like 20 RPM at a time. If you're seeing 100 RPM drops, you're milliseconds away from buying a new set of pistons
waxhead
wannabe backflipper
gold coast
That said, if it’s a recreational ski and not overloaded, you’ll be fine. Two-stroke jet skis don’t usually fail from over-revving — they fail from excessive piston load caused by running too tall a prop. If you err on the side of caution and keep the prop pitch low, the ski becomes more playful and fun, which is exactly what you want in a rec ski.
Even lean skis don’t blow up that often. If they’re lean enough to actually cause damage, they’re usually running so poorly they’re almost unrideable. Yes, we’ve all heard the phrase “richen it up and it won’t blow” — and that’s technically true. Adding fuel reduces combustion temperature, which helps the ski run cooler. But let’s be clear: that doesn’t fix the root problem — it just masks it.
An over-propped ski running a slightly lean mixture is a ticking gas torch. On the other hand, a properly propped ski running slightly lean will usually be fine. It won’t be at peak performance, but it’s not on the verge of meltdown either.
And before the “Made in China” crew jumps in — no, Wax didn’t say mixture and jetting don’t matter. What I said is that if the mixture is only slightly lean, it will be safe — just not optimal. If it’s really lean, it’ll bog or fail to transition onto the main jet, and that’s a whole different problem.
Just curious, did your plug read change after going to the taller prop?
waxhead
wannabe backflipper
gold coast
Did I plug read? Nah, I don’t plug read. Reading plugs properly means pulling them right after a full load pass—not idling back in—and even then, you’ve got to look at the base ring, not the tip. That’s where the real info is. Unleaded fuel doesn’t colour plugs like old-school race gas did anyway, and oil choice throws it off even more.
All my skis run black plugs because I believe in feeding the horses. I’d rather be rich enough to hold it wide open all day without burning anything down. Sure, I’ll trim it back enough to not kill top RPM, but you won’t catch me chasing lean just for a bit more revs and risking a meltdown.
dfw
With a “good” pipe power falls rapidly AND the mixture goes rich if the load is too light. Always, always, always open the top carb screw and retune whenever ANY changes are made! Wax illustrated how fine load adjustments can make a big differences. You want to set the pump load where you see a small rpm increase without any top speed gain. That’s the sweet spot and it usually takes some time and blade bending to find it. When it comes to reading plugs, I stopped trying to do it after I got a tachometer and gps. Whenever the ski ran best NGK #8 are always dark brown.
