I would have to ask someone about a leak test. Not sure how to do that.you said you rebuilt the engine correct? did you happen to do an air leak after assembly? if not, defintely do an air leak test to verify the engine is sealed up tight. compression test too just to verify both cylinders make even compression. i do both of these on every new engine i assemble as insurance and peace of mind. also check your popoff and jetting in the carbs. also something i do everytime i go through a carb is verify correct popoff.
I was going to check that as well.Also for what it's worth, I've installed those carbon tech reeds in a bunch of skis and occasionally (a coupla beers scenario) I find the reeds have a big gap. I flip them and reinstall the other way and they seal without any gap. I didn't think they had an orientation but some certainly do! Hate to make you rip the beast apart again but while your in there best to check.
You'll have to remove the carbs and exhaust. You can use expandable freeze plugs to plug the openings or make a block off plate. Then use a hand held pump like for checking popoff, connect that to the pulse fitting on the engine, pump the engine up to 8-9 psi and let it sit for 10 or so minutes. You can spray windex around case halves and gaskets to check for leaks.I would have to ask someone about a leak test. Not sure how to do that.
I have burned pistons with “pump gas” compression. Make sure your ignition timing isn’t too advanced and the carbs are set rich of peak rpm.I'm running 195psi per hole in my 735 with pump gas. This is with 35cc domes. If you're running 35cc domes you should be fine with pump gas. It's fully ported with all of thr bolt ons and have put 5 seasons on it like that and it's still running excellent.
I would check the compression with a decent gauge, I would not trust Harbor Freightlooking for the paperwork now but I think I ordered 35cc domes that are currently on the ski. They rate them at 185lbs.
If 192cc is still pump gas I should be ordering 36cc which calls out 177lbs. I’m making the assumption if this rebuild pushed me 10lbs above the 177lbs turn into 187lbs and I should be good. I’m asking the question as I do the math since I’m unsure of what the exact outcome will be.
Any thoughts?
This is an ADA head with domes that can be switched out. You might be right on the stock set up?I thought 36cc is the stock dome volume??
The head is an ADA so o-rings and all other gaskets are OEM.If you're running a thinner .010 base gasket, that will slightly raise compression. The factory gasket is .020. I'm running a .010 gasket in my engine.
What I meant was 36cc is 36cc..........won't matter on the brand, or even the squish band for that matter. If it's 36cc on a 701, it should only make around 175psi. So that's sort of wierd.This is an ADA head with domes that can be switched out. You might be right on the stock set up?
