Freestyle Bun pipe water routing for dasa 1200
waterfreak
I had a vision!
s florida
Anyonw have a water routing diagram for a lay down bun exhaust system for a dasa 1200 (extra cooling ports in front and back of cylinder)?
That's how I ran your motor/pipe .
Triple cooling.
-1 hose from the pump to the 4 cooling ports on the transfers
-1 hose from the pump straight to the bottom manifold
- 1 hose from the pump split between top of manifold and exhaust chamber water jacket
Then you need to T somewhere to bring water on the water injection point on the chamber
waterfreak
I had a vision!
s florida
Triple cooling.
could you provide me with a diagram ?
I was going to use a water port from HSI to feed the mtor since I only have two 1/2 inch cooling lines in the pump .
waterfreak
I had a vision!
s florida
Triple cooling.
Isn't there a reducer with a jet for spray?
