Yes but there are a few things you should know , it has to be stored in the can it comes in , as soon as you pour it into a plastic gas jug or your fuel tank it starts loosing octane , basically mix it up and ride all the gas out of it, it does not store at all, most guys mix it up at the site where they are riding it at , not mix it up at home and transport to the site.
The other thing is it requires jetting changes since it is an oxygenated fuel , so that means you pretty much can't run regular gas in it and expect it to run properly on it .
I personally haven't run it , this info was garnered from the guys I used to ride with and several of them ran it , they did the research on it and this is what they were told so the info should be quite reliable .
