- Connecticut
Hi all, here is my setup:
Dual 46
Low Jet: 130
High Jet: 132.5
Low Screw: 1 out
High Screw: 1.5 out
Pop Off: 18psi
-760 (84.75mm) with Mildly ported cases and Mild/Heavy Ported Cylinder
-B-pipe Mod chamber
-ADA head with 37cc domes, 170psi (raised ex port, less trapped volume)
-Hooker 10/16
(I am still tuning my ski, as i have been constantly changing parts and modifying things as an experiment).
Last time I rode my ski i noticed smoke emitting from the carbs after i shut it down. Also, if i pushed it into the water to force water up the exhaust tube, smoke would billow out AND i could hear the reed pedals humming a tune. So, i pulled the reeds (some kind of old dual stage reeds) and sure enough a couple pedals were opened up. So, i just replaced them with new VF3 reeds and put a Wax intake manifold while i was at it.
NEW PROBLEM: Ski will not idle on the stand unless i open it way up to probably past the low speed jet orifice. When running, it is spitting fuel up into the air in the form of droplets. I will say it sounds extremely snappy compared to the last time i revved it on the stand (old worn reeds?). But i am puzzled by the spitting fuel.
THEORY: Could this be that my low jets are incorrect? Could the worn reeds have been tricking me into improperly jetting my ski? I meticulously tune my skis, changing one jet at a time etc etc... I never ran this ski with new reeds before, as the first time i ever ran this motor was this season with those old reeds.
Any words? Posted is an image of the droplets resting on the blade. Thanks!
Dual 46
Low Jet: 130
High Jet: 132.5
Low Screw: 1 out
High Screw: 1.5 out
Pop Off: 18psi
-B-pipe Mod chamber
-Hooker 10/16
