- San Diego
I recently purchased a Zeeltronic CDI for the Kawi 750 in my x2. I had been running the 6 or 7 degree advance plate with great luck till I swallowed some water and broke a ring. Now Im on to a fresh 1.5mm over top-end.( 750 SP, SBN44, ADA 26cc, FPP Limited, 2” TDR baffled w/b) I ran a full tank through following break in procedure with OE electronics and no timing advance. Time for some timing!! So I install my new Zeeltronic PDCIS A02T per the diagram it came with and…no spark when cranking….Lame. So I went back to OE with the timing advance- works as it should. So obviously I must have it wired wrong. Has anyone installed one and can tell me what I’m missing? After trying the paper diagram with no luck I found the other slightly different routing but same basic path and tried it with the same result. I don’t have a controller so I can’t do the spark test. Any help is greatly appreciated!
