WB1 Riva Red pipe shimming
Hey guys, first time installing a Riva Red and it's going on a 760 that's going in my B1. Basically, I've read the posts about it and it has the studs put in and will have red loctite on every bolt.
I got a girdled head with the exhaust adapter. Didn't have the spacers so I used stainless washers to imitate a similar spacing.
Now I'm down to shimming. Manifold is bolted to the engine and I added the chamber. Bracket sits nice and flush to the pipe while loose. Only issue is height. I was just going to add washers between the head adapter and exhaust bracket until everything sits flush with bracket bolts hand tight...since it seems silly to keep raising up the adapter and have longer head bolts. Does that make sense?
Sent from my Pixel 6a using Tapatalk
Mike W
Infidel
North Florida
Digging up this old thread.
What did you figure out on this? Deck height lower on a 760?
