Portable lithium battery charger
DylanS
Gorilla Smasher
Lebanon Pa
I was wondering if any of you have come across a battery bank battery charger that I would be able to take to the lake when I run my total loss so I can charge my lithium battery halfway thru the day without having to fire up a generator.
I have a second battery I take along but pulling the battery out to replace it is a borderline religious experience.
Couldn’t find anything like that on NOCO’s page but maybe one of you knows about something I don’t. Thanks!
hmm I mean you could always use something like a jackery with say a 2A Noco charger but ideally want something that would do DC to DC.
I wonder if any RC car battery chargers would work as a lot of them run off of DC. I have one that has a PB 12v charge mode and runs off DC.
DylanS
Gorilla Smasher
Lebanon Pa
Thanks Batteryman I will have to look into that.
I believe the noco genius 5 max draw is 75w.
the smallest jackery is about 290wH so if you do the math for DC to AC loss I think I could run the charger at its peak for about 3 hours.
I’m thinking I’ll go that route unless I can find a DC to DC charger like you mentioned.
Myself
manic mechanic
Twin Lakes AR
How do you get to the lake? A vehicle? Why not just buy a $35 inverter from Wal-Mart, hook it to your car battery, and plug in your regular charger?
bird
walking on water
the NOCO batteries are LiFe, but they have intelligence built in... Do you even need a special charger?
My WPS/Firepower battery can charge up in 7 minutes or less at 20 amps with a standard deep cycle battery charger. The NOCO says it can take 21 amps max.
Stockton
I use this ^^^ method, but I also bring a extra car battery to charge at the ski
I use it outside my tent to charge the kids phones and stuff too… wife likes it…
DylanS
Gorilla Smasher
Lebanon Pa
Both places I typically ride I’m parked very far from the water side. One place has outlets about 40’ from the water but then I’m wrapping an extension cord around my pole and the coast guard generally frowns upon that haha.
DylanS
Gorilla Smasher
Lebanon Pa
You can use whatever charger I just picked up the noco charger because it’s charge times on the nlp16 are stupid fast.
The REAL issue here is that I just suck ass and I’m constantly starting my ski after bad landings. If I’d be more consistent I wouldn’t have to charge my battery :)
CD155MX
Squirrel!!!
Alta Loma, CA
If you have a few spare garage tool or yard tool batteries, you could use that as a source of power with one of their inverters to plug your charger into. Not exactly a DC to DC solution, but I've been using the Ego version with great success for charge kids Stacyc bikes when out camping.
Couple examples:
DylanS
Gorilla Smasher
Lebanon Pa
Couple examples:
Oh yeah haha I’m an idiot I totally forgot about the milkwakee inverters I think I even have one in the van. Genius dude that’s the ticket me thinks.
Maybe I can even convert the ski to run on Milwaukee batteries…
Thanks!
CA
Wish I saw this sooner, I originally wanted something DC-DC, and may still pursue that some day. But, I'm on team Ryobi here. :D I run an extension on the 12V side to keep the 120VAC away from the water.
bird
walking on water
DC over long distances can have significant voltage drop. Have you measured the 12 volt output voltage at end of the line? A lower voltage will take longer to charge the battery.
CA
Absolutely... I thought about that before, but, no I haven't actually measured the voltage. It's only a 3 amp charger, and once it's in absorption the current tapers which should also reduce voltage drop. I'm in no hurry. Even if it doesn't reach full charge at the lake, she gets a full charge back at home. Depending on situation I may not use the extension, either, it's been working well for Zeel with total loss. Deka ETX16L.
