DylanS
Gorilla Smasher
- Lebanon Pa
My suggestion to you is to find a aftermarket hull, probably Fglass because you’re learning on it, that has a piped 701 with bolt ons and go from there.
When you figure you have learned enough to move onto a bigger engine you can keep the hull and move up.
Im not sure how mechanically inclined you are but skis break, big engine skis really break. A lot. They get thrashed to no end especially by learners. You will end up spending thousands having someone else repair your ski and you’ll end up burnt out.
a big engine in a little hull is not even half of the recipe to do those cool flips you see all over the place. You will have a hundred attempts into learning how to setup and execute flat water flips consistently. Start on something cheaper and more reliable. Learn to wrench on standups. You’ll save yourself a lot of money and headache.
A decent AM hull and a built 701 the ski will capable of putting you full circle off setup wake with practice. Chris at JM can hook you up with a reliable badass sub 800cc engine too.
A 1100 properly setup is insanely violent and I’d highly suggest you avoid that for a starter lol. You wouldn’t learn to ride bike on a liter bike lol.
At this moment you are the limiting factor not power.
Do as you please just my .2 cents
