- qatar
Hey everyone I need help with my ski, 2015 superjet 701 stock head bpipe msd
Last year I was in the ocean and the ski had a failed coil, had to limp it back to shore, changed coil leads got spark and still its unrideable, and can’t figure out what’s wrong with it till now!!!
Ski runs lean in the water, I have to turn the screws all the way up to 3 turns high and low and still super lean, so I figured there is a leak somewhere???
So this is What I got done so far
-new crank seals
-new cylinder gasket
-new head gasket
-new intake and exhaust gasket
-new piston rings bearings washers snd locks ( decided to change when I opened the engine)
-All New electronics from stator to ebox
-new Yamaha fuel lines and check valve
-new gold sbn 38 carbs from highspeed
(140main-75pilot 1.5n/s and 95g springs) I went through them and clean 3 times
-checked reeds back to back from stock to vf2s no bueno
-new battery
I inspected the cylinder, cases snd the crank bearings during seal job and they seem good,
pressure tested the engine and it held 10psi for 5 min, 150/150 psi both holes,
On the hose the ski sounds crisp but forget running it in the water if not turning the screws all the way out,, I’m getting pulse, but the engine is starvinggggg
Is there anything I could be missing, im not sure what else to look for, thanks guys!
-new crank seals
-new head gasket
-new battery
