Not sure who might care about this but I figured I would document my findings.
I have been riding my Rickter FR2 for about 3 years now and have been pretty confident that I have found the best freeride hull for my particular riding style and needs.
Recently a Trinity Matrix Pro in -2" length came up for sale and I had to scoop it up to try it. Having ridden a couple of these previously I was feeling confident it would be a great freeride hull and even possibly a replacement for my Rickter. Again, there are almost no shortcomings to my FR2 other than it is a bit heavy and a bit dated looking (mostly due to the graphics).
The hulls are, generally speaking, very similar to each other in size and basic design, there are some minor design nuances that attribute to a pretty different ride from hull to hull.
My Rickter is: Glass hull, OEM 144 pump, ported 760cc frankenstein (64x cylinder, 61x cases, 46sbn), lim B pipe, zeel.
The Matrix is: Carbon hull, Solas 144 mag, Xscream 865 (XS 46s), mod B pipe, ATP ignition?
Both hulls are within an inch or so of each other in overall length, the Matrix is overall about 2" wider (both in hull and bondline), the FR2 has a wider tray and the overall mass of the driveline is set a couple inches back in the FR2 (even though hull length is the same, the FR2 pump ends up a couple inches further out of the rear of the hull than the matrix).
The FR2 has a very slight rear end rocker and a more gradual front rocker that starts near engine centerline or front motor mounts, it has slight scallops in the rear end (outside edge) and has wide, vertical rails and a front bondline.
The Matrix has a flat rear hull design, similar to a superjet and a slightly less gradual front rocker that starts more around the fuel tank area. The bottom deck is about 2" wider front to back than the Rickter, it has a similar scallop in the rear plus another one further forward sort of simulating an extra large front sponson. It has extra wide 45 degree rails and a small front splashguard under the nose.
