93 SN ran great now poopty, carb rebuilt, then replaced new. Video included.
Most likely the flywheel will be ok however there is no reliable way to test a flywheel, probably not exactly what you wanted to hear
So which part of the bendix grenaded? Do I need OEM washers and spring? I plan to get the spring from blowsion, but can't for the life of me find the washers. However, the description of the washer is "plain" so I'm hopeful I can just grab some from ACE.
Nix the blowsion bendix spring. $9 and change for the spring. Ok I bite the bullet. Cheapest shipping $28. That’s insane. It’s so light. Drop it in an envelope with a forever stamp. Under a buck shipped.
Kohldanielzimmer
Sierra Nevada Runoff Rider
Ahwahnee, CA
That looks like the weight spacer plate. New plate and spring can be obtained from JetManiac if you’re keen on rebuilding it. He also is a good bet for used or new OEM stator. Definitely recommend OEM electrical components vs cheap AM stuff.
I usually rob a spring from an old crankshaft seal, on the rest of the parts I have stacks of old bendix's for parts . i usually take a couple of them and make one.
Myself
manic mechanic
Twin Lakes AR
Houston......we have a problem, LOL! Yep just get a new bendix, aftermarket is fine on those and they're pretty cheap. As WFO said, the flywheel will probably be fine. There is actually a chance that the stator will work properly now that the metal is out.....or maybe not??? The metal bouncing around inside momentarily shorts things down.
