SOLD SOLD SOLD SOLD SOLD
Hull:
2014 Trendsetter’s Backie Chan
Fiberglass
Custom paint, top and bottom
Turf is brand new
2 custom ALUMINUM ride plates (Flat water and Surf)
X Scream Comp pole
Thrust OPV steering
Fri skeleton throttle and trim levers
Fri surf switch
Fri pole limiter rope
Thrust hood latch
Blowsion hood straps
3.3 Gallon Limited Slip Aluminum tank with battery tray
New intermediate housing and shaft
Dual 500gph bilge pumps
Motor:
X Scream SS900RR (New design cylinder, 9 port, same as their 900RR)
Fresh rings and power valves by X Scream this year, 3 months ago.
Dasa intake with V2 reeds
Dual 46mm Mikunis SBN
Zeel charging with lightened flywheel
JM surf coil
JM laydown water box
Power Factor pipe with port matched manifold
Pump:
148mm Torrent set back pump
New set back drive shaft
New Skat Trak 8/15 Hooker
Thrust Pro Trim with new cable
+2 Jet Dynamics intake grate modified
Extras :
All related Chan parts
All jetting specs
All timing curves
All the little secrets
Hull:
Fiberglass
Turf is brand new
X Scream Comp pole
Thrust OPV steering
Fri surf switch
Thrust hood latch
Motor:
JM surf coil
Pump:
Extras :
All jetting specs
All timing curves
