- Glenmoore pa
Some of you may know I've been working on a new ignition for our sport. It's really a car ECU (based on Speeduino) which i've trimmed down to mainly just whats needed for ignition control. I have a couple open design questions and would love your feedback
Connectivity
I can either have wires hanging out of the potted ignition which you have to wire (similar to an MSD) or some type of waterproof connector like https://www.mouser.com/ProductDetail/TE-Connectivity/770669-1?qs=bVE8zYB/q2eQrARJAzxzTA==&mgh=1&gclid=Cj0KCQiAq5meBhCyARIsAJrtdr5H21SPNzCxXeOYXOWVBCy7DHe4N_PBgnXTRzDZbEgHEYz3YxCULnEaAr_oEALw_wcB
The connector approach is better IMHO but will drive the board cost up about $20 and make it slightly bigger. It will also mean people need to crimp their own terminals on the connector end. Open to other ideas here
Latching relay (start/stop)
Similar to MSD, we need to use a dual-coil latching relay (shifty module) to make the start/stop functionality work like factory. Zeel integrates this in the "brain" and MSD does not. I will be using TE dual coil relay and could either integrate this in the main ECU or make it a separate module. I'm inclined to make it separate since this will make it replaceable (they do fail) and will move high current carrying off the ignition module. As it stands, my ECU/ignition draws very little power since its driving "smart" coils with their own drivers
GPIO
How much general purpose in/out do people actually want? My current design has two "high current" (2amp-ish) 12v general purpose outputs. You could use this to control 2 stage water injection or anything you want based on literally any criteria. On the board, there's loads of IO, but no actual circuits to facilitate I/O. I could pretty easily add general purpose analog inputs for things like a pressure sensor, EGT sensor, etc, but this will add size and cost to the board. It also adds potential for people to do dumb stuff with this. Would love feedback here.
How people buy/get this thing
If i ever finish this project, I want to offer all the info in an "open source" way. I may not share the actual board design openly, but everything else will be "open source." It's all based on open source stuff anyway. I'd also consider selling boards and maybe kits. I was thinking people might like to buy this in the following configurations, but maybe this is too much:
Would love to hear people's thoughts on everything. Thanks!!
-Jordan
Connectivity
GPIO
- bare board - cheapest but most advanced. Add any GPIO circuits you want, pot it yourself, add your own wiring
- Potted board with wires or connector. No coils.
- Potted board with wires or connector. Hall sensor, trigger wheel and epoxy/weld on front cover adapter included
- Potted board with wires or connector. Hall sensor, trigger wheel, front cover adapter, cheap coils for a budget build
- Potted board with wires or connector. Hall sensor, trigger wheel, front cover adapter, high end coils for a high end build
- (maybe) Potted board with wires or connector. Hall sensor, trigger wheel, high end coils, custom billet front cover with hall sensor hole
-Jordan
