- Buffalo
Looking for stock sxr800 mikuni carbs and intake manifold
Any info on how you modified the carbs? I actually have a set of mikunis laying around from a Sea Doo. I never thought to try them on a Kawi due to the carbs being mounted sideways with a throttle linkage.Actually they are the correct intakes Storbeck, those are for big pin 750 -SXR with SBN carbs, the way you tell the difference is simple 8mm bolt holes versus 6mm and the dowel pins, all of the SBN manifolds have dowel pins and spacers and run 4 gaskets, the Kehin intakes have no dowel pins or spacers and run two gaskets, you have to remove the dowel pins to run the Seadoo carbs on these intakes or drill the carbs to accept the pins , the Kehin intakes also have oil injection ports in the intakes, the big pin 750 SXR intakes do not have them and they are not drilled for them.
Here is a pic of the ones that I have, those are not SXR carbs on there they are off a Seadoo 657x motor and they have to be slightly modified to use on the SXR manifolds, SXR carbs are 40mm I body these are 38mm I body carbs , I am running Seadoo carbs because they are easily obtainable and I have a few sets laying around here, SXR carbs as you can see from this thread are not easily obtainable.
