- Alabama
I think you are right on that Sturat
Thanks for posting back that this solved your issue, it may make it much easier for the next guy.I need to apologize for my misinformation. I followed up with the guy who built the engine and modded the pipe to fit my boat. It is a R&D Superjet pipe and has had the stinger cut and clocked to fit for my application.
Anyways, the way it is setup in my last drawing has worked wonderfully. I cut a bunch of water out of the exhaust at the injection point closest to the head and a bit at the stinger with the valves as well. It had a lot more power out of the hole, so much so that it would overspin/cavitate the prop and I had to feather the throttle a bit to get the boat going from a stop. Keep in mind the boat is probably close to 1000 lbs with two big people in it. Once I get the pipe and the carbs dialed in, I'll address that part.
Thanks for all the help and happy ripping!
