- Syracuse Ny
post dimensions of the front of your tray and I can help you out with measurements later if Tomski hasn't chimed in... they are solid on the sides so even if your tray is wider its not a big deal. I am running mine with gaps on the side but filling the gaps with underpadding before turfing so it will appear to run the whole width of the trayWill this work on my EME Aerial 8? I’ve been hunting for something like this for my front foot
Does he have a website I can order it off of? Or should I just send him a PM?It sounds like it will fit just fine, but the foot hold won't reach wall to wall if that makes sense, so you will either have a gap on each side or you can fill the gap with foam/padding and then turf over it to make it wall to wall .. I'm getting 12-3/4" for the width of the hold itself and then I have actually trimmed the flange around the hold so I can't give you the original measurement there... but it was definitely less than 15" to start with... it should fit your tray without modifications. Depending on what's on your bulkhead/firewall you can either through bolt it (what I'm doing) or it can be epoxied/glassed to your hull... I'd say go for it, they are made really well.
Damn lol
You need to post 5 times and then wait an hour or so for the hourly "task" of updating user permissions to run automatically....I need one for a 94 square nose single piece design. New to the sight won’t let me follow the link or pm.
Very nice product.Sent you a PM. if you're still making or have any, I'll take one for my SN.
I Also sent a pm with no response...who else Is making these??Sent you a PM. if you're still making or have any, I'll take one for my SN.
