- North Central Pennsylvania
Parting out my Yamaha 64X based Able 770cc. The engine had right at 140 hours (Yes, I keep track) and was running great. I ran this the entire 2019-2020 seasons, and used it the last two summer as a backup and it got very little use. I had Matt at HPE build this over the winter of 2018-19 right before he fell off the map. You can see from the piston wash I ran it very rich. Built on 64X dual pulse cases, they are trenched and epoxy filled. Original black paint thats nice. All threads good. No issues. There are a few cosmetic scratches in the bottom of the cases in one side that must have put in when building it, as there was nothing in it at tear down and was spotless. The cylinder includes the B-Pipe manifold, head, pistons with pins, and hardware. As seen in pics both cylinders were making right at 190psi. Cylinder walls look great and head is also in great shape. Pistons only have very minor scuffing. This could be ran as is right now. The ADR crank includes the stroker spacer plate and hardware. A couple of the bearing make the slightest of noise, but it does have 140 hours on it. No play in rod bearings. May be able to use it, but I would get it rebuilt. The carbs are Mikuni SBN retail 44s with a Rhass O-ring intake and Carbon Tech Reeds. Inside and outside of carbs are mint. Reeds look good. Shipping will be $35 east coast or $55 west of the Mississippi. Buyer pays Paypal fees or can use Zelle or Venmo. Cases $350 Able setup $850 ADR crank and spacer $350 Carb setup $350. I have detailed pics of everything. Let me know if you need them.
