Hurricane hull with everything but engine
denmark
engine blew again soo i am leving the sport for now
Hurricane hull carbon competion 2016 model painted nardoporche grey in 2021 got new turf at same time comes with ride plate 155 mm pump shoe dual duck bilge jetdynamicintake grate
RRP ninja footholds modified too fit hull
RRP pole bracket with dual breather tubes
RRP fat bar (handel bar ) with ODI grips
RRP reat mounted gas tank (g1 model) comes with 9 L “normal freestyle tank also
ZEELTRONIC 64x ignition with oem coil and flywheels for charging and TL oem SS switch
TITAN adjustable pole with ATP crush bar bolt MAXX chin pad in hull color
PITCH COMPONENTS steering system
PITCH COMPONENTS complete trim system with lever/cable interactable rings for fine tuning
MAXX 155 mag pump stainless steel one piece setback pump
SKAT TRAC 155 mm impeller setback thin blade around 12/17 pitch works but doo have dents
POWER FACTOR PIPE with TJ PRODUCTS alu water box manifold has been welded after impact with crank rod all good and has been run for years, chamber has been modified too fit different hullo
FULL SPECTRUM 49s jetted for ET1107 with double siphon valves
PHP intake manifold with speed plate
OEM steering and throttle cable
OEM starter has some marks from con rod works fine
OEM midshaft with coupler
JETMANIAC rebuild Bendix
GP motor mounted
located in EU will g’et more pics
12500 usd for everything
