Hey guys and gals. I have been working on a Superjet 650 1991 for a while, at first it was getting no spark so I replaced the CDI ignition coil and stator which all had seen it’s 30 years of service. Finally got spark to the plugs so decided it must be a fuel problem, replaced 20 feet of fuel line put a new fuel filter and water separator, still have a fuel check valve that I’ve not put in because I don’t know where to put it yet. Now it smells like it wants to start and sounds like it wants to start and it’s getting spark but it just won’t start. I have both the carb jets out one and an eighth turn. Pulled the carb apart and everything seems to look clean inside, not sure if it’s the factory carb but I just don’t know where to go next. Any suggestions will help,
thanks to all, William
