- Sacramento Delta
It is very difficult to cruise slow with big carbs and a good pipe. It will tend to be on or off. If you want it really smooth then install a set of OEM 38mm carbs and a stock Superjet pipe. You will lose some max pull and speed but the throttle will be very linear.
@allted Have you considered that your ski may actually be functioning as it is designed as modified?
I briefly rode @wavewarrior's piped Super Jet and it was like that. Idle or Hyperspeed and nothing in the middle. That is how it was supposed to be. He said I would get used to it, and I am getting parts together to put a pipe on the FX-1, however, my guess is that I would prefer a more linear increase in power so it will be an interesting experiment.
