I bought a superjet from a guy a while ago.
Put it in the water and it was running bad. Rebuilt the carbs with oem stuff. Ran much better.
There was a run away at idle out of the water. Then it seemed fine. Runs good in the water but idle is funky.
I think it’s the crank seals. I dropped it off with an acquaintance/friend of mine who knows what he’s doing.
We almost just pulled the bottom case off and did the seals but it looks like it had a stroker crank possibly. We’re just going too pull it all the way and check.
Any ideas on what crank this is?
