- Red Bluff CA
I have no idea what he built this for. I cannot get any engine or manifold combo to clear the ebox. He even used the rickter carbon e box plate. Like how the hell do you mess that up?????I haven’t seen any Rickter setup where it’s setup for both a lay down and a b pipe.
Although I did see Joel Barry mount his ebox to his motor.
Maybe there is a better method.
Ebox on the engine is what I almost did. That's what the 1100s did factory. And although I've read about cdi issues caused by vibration, there is a ton of them out with with 3 or 400+ hours on them.
I wanna see someone with a xfr, rrp tank, pfp pipe, that used a PFP WATERBOX. I could not see any way possible at all to use the pfp box. Unless the rickter battery tray was completely removed. It was going to cause the box to sit WAY too high
Sent from my SM-G970U using Tapatalk
