Yeah it will kind of kick back and it’s been blowing my pv boots off also.
Yes mine did that too, liquid fuel and fuel vapor would build up in the crankcase and exhaust and randomly ignite while trying to get the dang thing to crank fast enough, long enough to start and run on its own…
When it’s cold out my Lipo battery can’t crank my engine fast enough and I get the same rut rut rut type slow labored cranking that precedes the kick back and backfire, so I have to heat the battery with my trucks heater first to get her to crank fast enough to start… in cold weather
Dylan’s correct, do what you can to reduce your cranking timing, 10 or 12 degrees would be good… lipo battery needs to warm. If your issue persists your issue may be elsewhere like JC mentioned
Btw, The Epic HX3 ignition I had could not start my engine without major kick back and random backfire. No matter what I did with low RPM timing, timing offset, my timing light always showed the same starting timing…. Turns out That ignition has fixed start timing and is not adjustable, even though the software lets adjust the curve, the programmed curve is ignored until it running.. pulled my hair out on this…..so couldn’t use it on a 1200cc engine, worked good on a 8 mil 865, but would hard crank at times, usually first crank but second crank was faster and ok..
Jc, from all this, I found engine cranking speed is around 175 RPM and the enhancer start timing verified @ 12 deg….I also got the curve file from AirTime Products had contact with MSD on the enhancer curve and TL curve details..
400 RPM is faster then cranking speed, the engine is already beginning to run and the timing is at a different rpm point in the curve like you mentioned above..
