- Asheville, NC
Im finding that almost every insert thread on this ski is loose if not already stripped... Not sure why these hulls were built with cheap aluminum blocks as "inserts" but these ones have taken a beating. The last thing I ever want to do is cut this tray open again! I did some research and thinking and decided to help out the midshaft threads by adding a 22mm deep 316 stainless Rotaloc on the backside of the bulkhead. I aligned them with long bolts through the midshaft holes and used thickened epoxy and chopped strand to hold them in place. I then put 1 layer of 6oz cloth around the inserts and then a layer of 1208 biax over each insert. Finally 1 last large layer of 6oz cloth covering the entire midshaft. I even added a little last blob of thickened epoxy to make me feel warm and fuzzy. All of the bolts now thread in by hand to the very back, so with the added 22mm my full thread depth for the midshaft is about 35mm! If the original holes ever strip, I can just use a longer bolt. As a matter of fact, I could even use a longer bolt to start with and never worry about stripping my midshaft bolts. Keep in mind, im only doing this because all the threads on this hull are loose and look like garbage.
