Quinc
Buy a Superjet
- California
Been going over how to build one of these in my head for a while without breaking the bank. You can fill the outside of a barn with what I dont know so if you have an idea or suggestion let me know!
Goal:
Launch ski into the ocean and leave the cart floating in the water while I ride.
Haul kids and ice chest, portable hot tub I recently built, firewood, etc etc
Materials:
Lawn tractor wheels 20x10-8 $FREE
24v 500w 6:1 gear reduction motor $105
lifepo/AGM batteries, haven't decided yet $60-100
3/4" live axle with keyway $25
sprocket $30
420 chain $15
Gokart axle odds and ends $40
Pillow block bearings/impregnated brass $25
Scrap metal
Plan:
I got my inspiration from a trailer dolly. My plan is to build a 2 wheel cart fully contained with an adjustable ball hitch on it. This way I can add a hitch to my current beach cart to haul down to the water, then unhook it and push the cart by hand rest of the way into ocean. The ball will also be used as a pivot for steering (still need to figure out how to stable it for back and forth play) and I will make a long handle that will have a throttle and fwd/rev switch. Obviously these plans can and probably will change as the build progresses.
Here is where it sits currently. I have been slowly cutting and tacking together a frame. Once I have it all figured out I might redo it in aluminum. but most likely just paint it and call it good.
