Old school hydraulic trim
I bought a superjet that has this trim setup. It uses hydraulics to move a steering cable thats attached to your trim. Very beefy compared to the bike cable trim setups.
Anyone have any idea who made these? I wont be using it if anyone wants it. I dont have the lever unfortunately.
Thanks for the info guys. I was looking thru old threads and one looking like mine came up and was thought to be an SRE design. Dont know for sure. Hate to throw it out i dont need it.
There was probably several that made them. Really easy to make if you had the machining tools to make it. the Hydrolic Actuator is very common. You pull the lever and it basically pushes a button out. When attached to the rocker arm it would push the Nozzle or Trim Tabs down.
I did some searching for baker seadoo trim and sure enough thats what it looks like. Seems a very stout unit. I wonder if i could find the proper lever for it. Its setup to push a cable right now which drops the nozzle. Be cool to rig it to lift the nozzle.
You would have to make the change at the pump. Basically flip the mech. around to push the nozzle up. (Pull Forward for up)
