Thank you I was afraid someone would say that, Is there a specific way to do that, can't see my harbor freight calipers fitting up in there lol.Measure in inside diameter. Most likely a 144 or 148
That is what I was afraid of hearing lol, thanks.pull the pump.
How do I tell if the wear ring is stock? I've only ever had older Kawasaki's, yamaha is new to me.Also if it's a stock wear ring it's probably a 144.
Stock wear rings will have an aluminum housing.
OK, thank you both!!As Kevbo said the stock wear ring is a stainless liner in an aluminum housing. Solas sells solid stainless wear rings (the whole housing is one piece stainless) in both 144 and 148 sizes, so if it is a one piece housing that doesn't really tell you anything.
That's a way better idea than what I suggested.![]()
12 in. Locking Wing Divider
Amazing deals on this 12In Locking Wing Divider at Harbor Freight. Quality tools & low prices.www.harborfreight.com
