Quinc
Buy a Superjet
- California
Got this jetmate for the wife and kids. Came with a rebuilt 650 engine and wiring mostly done. I added new jettrim seat covers and a 100$ Bimini top from amazon. After having what I believe to be electric issues with the mate not letting it rev up in the water. I bought the rhaas adapter plates rather then spending money to fix the 650.
I have a stock bore 62t out of a waveraider I rebuilt with a new hotrods crank. new seals and gaskets etc, r&d head with boyesen rad valves and dual 38s.
Putting the rhaas plates together I noticed the bolts are too long for the engine mounts so I swapped them out to shorter bolts. If you dont have shorter bolts you can add a couple washers to them.
Pic of the mounts in the hull, when fitting the engine I found everything lined up best with them pushed all the way forward and in toward each other.
In the top left of the pic the 3/8" green cooling line is from fuel-line.com and fits perfectly where the stock 1/4" pisser line is. The home depot 3/8" braided line OD is too large and will not fit.
I was hoping that I could fit a lay down pipe the hull but the fit was not even close. So I will be doing the cheater pipe (bpipe manifold with stock exhaust).
For anyone that has done a 701/750/800 swap do you drill out the stock waterbox?
For the pump/impeller I wanted a skat 10/18 or hooker 10/16, but skat and impros are backordered for the next 4-6weeks so I picked up a skat 15/18. Worse case I can send it to impros and have them repitch it.
The jetmates run hot so while I had the pump out I swapped out the npt fitting for one with the largest ID I had. If she still runs too hot I will retap the pump for a 1/2 npt fitting. Or maybe dual cooling.
Next step is figure out how I want to mount the ebox and wire the switches.
