Hey guys.
I have a 750sx, all stock. Runs great other than its a bitch to cold start, as well as it'll bog and usually die if I idle for a bit and then go WOT. For it to stall, I have to idle first for a bit. If I do a very short idle (less than 1-2sec), and go straight to wot, or if I roll into it WOT, for the most part runs acceptable/fine. Everywhere else in the rpm range it runs fine.
Carb is the keihin CDK2, with verified stock jetting.
Engine has 150/150 in each hole and engine holds 7psi for over 10 min.
High speed screw is 1 screw out. Low speed is like 1 1/4 (where ever I got the highest idle speed on a warm engine). I rebuild the carb.
Reeds are in amazing shape.
All fresh intake gaskets.
New stator last season as my last one wouldn't work when it got hot.
Thanks!
Thanks!
