Ski Package Deal - 2010 Trinity Matrix Pro and 07 Freeride SJ on Triton Trailer. SOLD!!!
OCD Solutions
Rentz, GA
This is a bittersweet topic for me but ultimately, we stopped riding a few years ago and these skis deserve to be ridden.
No expense was spared during these builds.
I don't have time to nickel and dime so I'm looking for a package sale that includes both skis, SquidMoose Hitch Hauler, my custom Triton Aluminum Trailer, a TBM Beach Cart and AC Racing folding scissor stand.
Starting Price is $25K for the entire package
2011 Trinity Matrix Pro -2"
(Original Build Thread) https://www.x-h2o.com/threads/boyer...-ss865-144mm-setback-mag.133641/#post-1471571
Hull;
2011 Trinity Composites Matrix "Pro" Carbon hull, -2"
Trinity Footholds
Dual Thrust Scuppers mounted in the pump area, (Currently Plugged)
ATP Performance Waterbox
Stock Fuel tank with Wamiltons Billet Internal fill
Thrust Innovations Billet External Fill
Engine and electrics;
X-Scream SS846 Billet cylinder kit (anodized black) (195 psi)
OEM Trued and Welded crank
64U Cases ported and epoxied by X-Scream
Boyesen/Full Spectrum Extreme Velocity Intake
Dual Mikuni 46's modded by X-Scream and painted black
B-Pipe modded by X-Scream, (limited chamber) and ceramic coated by airborne Coatings in Denver, NC
Prok Filters with Outwears
JSS 62T Stator with JSS Stainless Laser cut washers
JSS Coil
TBM Lightweight Charging Flywheel
Cold Fusion Billet Flywheel cover
Billet UMI lightweight couplers
ATP E.P.I.C. programmable ignition Module
Deka ETX-12 AGM battery
Custom aluminum mini Battery box
GP800 Motor Mounts with Kenney Keepers
Pump and handling;
144mm Solas Stainless Pump
144mm Solas Stainless Wear Ring
Skat 13/18 Swirl Impeller
Worx 201 Intake Grate
Stock D-cut Rideplate
Steering and handpole;
RRP Handpole with black annodized tubes
RRP Dual breather bracket
RRP Chinpad support bracket
RRP Pole Spring mount
Stock modded pole spring
ADA Sealed bearing steering system
X-Metal -2.5" Turnplate
X_Metal Straightbars
Wamiltons RRP Chinpad
JSS Start/Stop switch
ODI Grips
Sato Finger throttle
Kawi HD 650sx Throttle cable
Hot Products Adjustable Throttle Drum
2007 Yamaha Superjet
(Original Build Thread) https://www.x-h2o.com/threads/in2-h2os-07-superjet-build-sleeper-project.49919/
Build List;
Hull
Stock 2007 Superjet Hull
#.0 Front Sponsons
WDK Lowered freestyle Hood painted black w/factory decals
WDK Nosepiece
RRP Lowered handpole Mount, dual breathers
Rickter Footholds
Hydro turf mats
Engine
84mm TLR Race Ported 62T 760cc
Riva 62T Ported Cases
ProX Pistons
HotRods Crank
ADA Girdled Head w/34cc domes
Dual Taper bore Mikuni 38's
JSS Billet Mixture Knobs
Prok filters w/outwears and Riva adapters
MSD Enhancer Ignition
JSS 62T Stator
JSS Ebox and cables
JSS Start/stop switch
TBM Charging Flywheel
Factory B-Pipe with "Blue" Carbon Mod chamber
Stock Waterbox
Kenney Keepers
UMI Billet Couplers
Pump/handling
Hooker 11/17 Impeller
Quick Steer Mods to steering nozzle
Steering
RRP Adjustable Pole
ODI Grips
Limiting Strap
SharkFab Finger throttle
Wamiltons -2" Turnplate
X-Metal Straight bars
Misc other parts
Dual 500 GPH Bilge Pumps
Tidy Bilge Dual pump Harness
Black Billet bow eyes
Black Billet Bilge fittings
Black Billet Bypass fittings
Custom Aluminum Battery Tray for smaller Deka style batteries
SN Fire Extinguisher Holder (turfed to match)
All Stainless Allen Head Bold Hardware, Engine and Hull.
OCD Solutions
Rentz, GA
Matrix Pics
OCD Solutions
Rentz, GA
Some pics from the original build;
OCD Solutions
Rentz, GA
Package includes;
- Triton Trailer
- SquidMoose Aluminum Hitch Hauler
- TBM Beach Cart
- AC Racing Folding Scissor Stand
This trailer is an older Triton Aluminum trailer that was shorted and converted to carry two standups.
- Added HDPE covered aluminum bunks spaced to allow for two skis or one to be centered.
- Upgraded to 13" Radial Tires
- Spare 13" Tire
- Custom fuel rack that includes 3 AC Racing fuel jugs
- Beach cart mount for TBM cart
- Adjustable axle mounts to better tune the balance of the trailer
OCD Solutions
Rentz, GA
There are around 75 hours on the Matrix and probably half that on the SJ.
Somebody gave me a $100 gift certificate for Christmas in 2012 and I used it to buy 4 gallon jugs of Quicksilver oil.
This package will include the 2 remaining gallons of oil I never used. :eek:
OCD Solutions
Rentz, GA
OCD Solutions
Rentz, GA
Tossed new batteries in these and took them to the lake for the fourth of July weekend for a couple friends and perspective buys test them out.
They both cranked right up and ran solid all weekend after sitting for the better part of 4 years.
So solid in fact we decided that they can sit for another 4 years for all we cared. :)
The package deal is still available but the price is non-negotiable.
The Matrix build was $32K in parts alone and the SJ was $13,800 so I'm not entertaining any low ballers or tire kickers.
