Rickter xfs g2 intake grate
Krenn Power Sports
the g2 intake grate i believe is different than the std xfs.. and the g2 they don't make in carbon core...
so, im guessing you need just an xfs intake grate if yours is Carbon Core...
It might not be identical bottom then but for sure the same pump tunnel and takes the same intake grate
Again not necessarily correct. The G2 pump tunnel is oval shaped where the G1/carbon core tunnel is more rectangular in the opening on the bottom of the deck. They both use a +2 intake grate. I have a 2020 carbon core, looked into making my own intake grate but it was just more time efficient to buy the carbon one from rrp. A +2 JD intake grate I am told will fit.
